- Joined
- Nov 8, 2017
- Messages
- 19
- Reaction score
- 3
- Age
- 79
The camera mount has two design issues as I see it. The first is that the wires need to have a connector between the camera and the base. That way if the camera does come off the connector unmates rather than breaking the wires off at the ring as my Typhoon H did. My Blade camera was mounted using a connector. The second are the plastic pins that are suppose to keep the camera from falling off. My use of 4 tie wraps to replace the pins worked well but your idea of small screws and lock nuts sounds much better and professional looking
