Typhoon H plus
So if the websites are 180° opposite, would that would qualify as "backwards compatible"? :rolleyes:
So does this mean the H that out just now will drop in price personally I don't think so what do you guys think am still sitting on the fence weather to buy the h as you can get it just now or wait I suppose have to weight up the pros and cons ie do I want the very latest or buy current H as still enjoy flying my Q500+
I doubt it will make a huge difference in flight time myself. Maybe a minute less I would guess.
Has anyone tested the H with no camera to figure out what it actually uses?
Does anyone know if the H and the H Plus will use the same battery?
No, they have different specs. It appears the 520 and presumably the H plus will use the same battery, It seems to be a high voltage LiPo.
H
5400mAh 4S/14.8V(79.9Wh)
Charger SC4000-4
520
5250mAh 4S/15.2V (79.8Wh)
Charger SC4000-4H
In their video Yuneec is stating that the H+ is stable in winds as high as 30 MPH. That's quite a bit higher than the 12 MPH max wind they recommend for the H.
Looks like the H plus will use the H 520 batteries.
Neverheless there are numerous reports of the 520 taking H batteries as well (but at a shorter flight-time of course). So one could assume the H plus will function with H batteries.
mikedh
