Typhoon H520E Issue
Greetings from Germany. I'm hoping you can give me a little advice.
I have a Typhoon H520E with a thermal camera that I got from a friend, and I want to revive it if possible. It was standing in the field two days ago, ready to fly, and then the remote control crashed. After that, it was impossible to connect to the Typhoon.
I reinstalled DataPilot, but now I suspect something is wrong with the Typhoon itself. After turning it on, it just stands there with the left arm red, the right arm green, the front arms white, and the rear arms blinking purple.
From what I've read, this means it's in Angle mode without a GPS signal, so it did not initialize. Is there a way to fully reset the Typhoon? Also, I can't get any connection through the Typhoon GUI.
I don't want to throw this thing away. It can still be useful if I can get it to fly again.
I had a similar issue with a h plus.
Read the thread Typhoon h plus , no gps lock
I’d wait for other suggestions first , it might be something more simple
My one was also showing enough satellites on the controller for a gps lock, have a look at urs , if it has enough (10+) it could be same issue. If no satellites it could be the gps module itself. I think the gps module is the same across the hplus, h3 , h520 and h520e
"remote control crashed."
Please describe the symptoms of the crash. (Did the screen freeze? Did it shutdown? Would it restart? ...etc.)
"I reinstalled DataPilot"
Did you perform a factory reset prior to installing DataPilot?
What version of DataPilot did you install?
How did you install DataPilot? (source of files, method)
"impossible to connect to the Typhoon."
Did you bind the H520E to the controller?
What method did you use to rebind?
"blinking purple."
Is the unit outside with a clear view of the sky?
"I can't get any connection through the Typhoon GUI"
The H520 does not work with the Typhoon H GUI. I do not have an H520E available to check, but I doubt it will work either.
cpassenheim
