Upgrading Issues
I upgraded my H Plus to Build 784 the other day. I finally got a good afternoon to fly and I cannot get the transmitter to stay connected to the C23. It's connecting to the C23, but loses binding every time I mess in the settings. Now the transmitter says I'm on build 1.1.02_20181122 and it says there's an upgrade available to 784. It shows the upgrade is downloaded and when I click on the "UPDATE" button, it does nothing. I'm also getting the red triangle in the photo below for a split second, and then it disappears. Any ideas what's going on here? IMG_20181211_174848615.jpegIMG_20181211_174729692.jpegIMG_20181211_174734166.jpegIMG_20181211_174739653.jpeg
Copy your APK or better yet your whole build (alway have a copy of each build)
Restore your ST16s to factory settings, re-download APK to you ST16s and redo the firmware update.
There is a thread devoted on how to downgrade and upgrade a build manually.
Just out of curiosity, what does your firmware version say? When I go to the Android settings > about tablet, it says 1.1.02_BUILD784_20181122. But, you see what it says in the app in my OP. It's just missing the "build 784" part.
Ha. Now it says no updates required. View attachment 13066
Don’t take a chance, you want the update to be flawless and there are updates that doesn’t go smoothly, due to WiFi. Just to be have a peace of mind, I would do a hard instal (manual) instead of a soft install (WiFi)
I am one to do hard install it has been workflow for me. Yuneec does not provide a downloadable update for the H+ so, we are just actually rebuilding. You will also find the files in the SD card after you’ve upgraded the camera.
You can reset your Android tablet, and if you brick your tablet, it is also an easy fix
Reactions: TurboDad81
snoopy68
