You can have both, an additional tablet and the videodownlink to ST10. But keep in mind that the WiFi antenna of the tablet is not as good as the patch antenna inside the ST10.
You need the CGO app on your Android device. It must be able to use the 5GHz WiFi band. The app is available in play store.
Okay, thank you for this information. Some day i will try this .I think this will not reduce the traffic. The mass of data are the packages from video strem. Those IP packages sent once went to both devices. A little bit handshaking and/or commands are less.
RTSP protocol is point to multi point. See here:
http://www.ijsrd.com/articles/IJSRDV3I40244.pdf
However, you can unbind the CGO3 cam from ST10.
