Warning Military GPS Knock Out !
Texas
Please Read !!! You Could lose GPS from California to New Mexico in these date !
A NOTAM is warning operators of “all aircraft relying on GPS” of widespread GPS outages starting Tuesday throughout the Southwest and especially southern California. Although the FAA doesn’t go into detail, it seems the military is testing something that can disrupt GPS over a huge area, centered on China Lake, California, home of the Navy’s China Lake Naval Weapons Center. On Tuesday, June 7, the FAA is warning that GPS signals down to 50 feet AGL could be “unreliable or unavailable” between 9:30 a.m. and 3:30 p.m. local time over a radius of 253 nautical miles, which includes the L.A. Basin, Bay area and Las Vegas. There will be further outages of similar potential duration June 9, 21,23, 28 and 30. The circles expand with altitude and at 40,000 feet the interference will affect a circular area of the Southwest 950 nautical miles across, reaching central Oregon, Colorado and New Mexico.
The tests will potentially knock out all GPS-reliant services including WAAS, GBAS and, notably, ADS-B. The FAA also doesn’t want a lot of radio chatter about the outages and is urging pilots to report them if they need help from ATC. Operators of Embraer Phenom 300 business jets are being urged to avoid the area entirely. “Due to GPS Interference impacts potentially affecting Embraer 300 aircraft flight stability controls, FAA recommends EMB Phenom pilots avoid the…testing area and closely monitor flight control systems
yikes. I was told they usually run these tests over night, but 4-10p is prime time...
Sorry Cogito and thanks, I see you already posted too ! Good Job !
No worries. You have a better headline than mine. One thing I would be worried about is if I recorded a Curved Cable Cam route on a previous day I would be wary of trying to fly it Tuesday, or any of the other listed days.
This was recently discussed here. Be sure and check the search or look at the suggested post at the bottom as you are crafting yours. ;)
Thread closed. Please comment further here - GPS Interference NOTAM For Southwest
tmsmindspace
