Wavey footage after crash
Hi All
I recently crashed my Q5004K and it was a pretty bad crash, I broke all the props and the camera was partially removed from the drone so the wires broke on the camera. I was able to hard wire the camera to the drone
with the wire supplied and reinstall the rubber dampers. When its not flying the recording is perfect but when I fly the drone the footage is wavey and the higher I fly it the worse it gets. It's not watchable especially flying high. Any help would be greatly appreciated. Thanks in advance.
Dixsey.
For clarification, are you referring to the video recorded on the sd card in the camera or the video feed to the controller?
Reactions: DoomMeister
This can be caused by vibrations. Especially after a crash this is very common. Take a look if you notice any vibration or if you can see one or more motor shafts wobbling around when turning.
Reactions: Pier2162
SamHembree
