Date of latest revision: 11/13/2025
Added guidance for creating and saving screenshots on the ST16 series of controllers using an SD card.
Why not use the USB cable to transfer files? For MacOS user SD card may be helpful if Android file transfer was not installed for other purposes. But for Windows (ST16 needs to be fully booted up) or LINUX (no problem) the USB connection is far easier than SD card handling.
Or do I miss something?
Topic was discussed before. Depends what kind of device your Windows host sees.
SD card is convenient way for most of traditional users.
Reactions: WTFDproject
Just have not written it yet. Be patient. 😂
I wrote the SD card version first because more people have SD cards than data capable USB cables.
Date of latest revision: 11/14/2025
Added guidance for creating and saving screenshots on the ST16 series of controllers using a USB cable.
Reactions: h-elsner
Date of latest revision: 11/15/2025
Very minor revision. Combined the previous two guidelines for ST16 series screenshots in a common folder to simplify the selection. The combined link was moved to the "ST16" section of the Table of Contents.
"ST16 Series Screenshots"
Could you please create an APK file compatible with current Android versions?
I do not know of anyone with Android skills at that level.
@Doomeister may know which android versions should work with the current CGo3 App.
Some members have worked around the problem by buying an old Android phone just for flight control.
Date of latest Revision: 06/28/2026
Added drawing for H520 motor wiring color. The wire colors are not always a match between the color of the wire on the board vs. the color of the correct wire on the motor.
GiftNexa Jaipur
