Please add the documents as PDF's in the WTFD project.
To raise the interest is the best to make a fast look instead to go to some links.
Reactions: cabinfourus
Yuneec- specific data and control message formats (Yuneec MAVlink
messages, SR24 messages, GUI messages):
 H480_UART_readin.....
Link is wrong and produces 404.
This is unreadable as PDF.
I referred to Vaklin's post #102. The format sheets exported to PDF produces useless and unreadable PDF files. Useless because you cannot select and scroll that messages which are often too long for a PDF sheet.
Sorry for misleading expression.
Revision 06
Added a new section for "Normal Binding Process Videos"
to provide links to videos of the normal binding sequences when no technical issues require use of the Binding Verification documents.
Date of revision: 05/13/2025
I would like to start a small youtube series using the typhoon h yellowjacket (john’s personal drone he sold to me) This would include a everything from antenna changes to all pre-flight checklists and how everything works with models and the camera, etc.
can you please let me know if these original Yuneec manuals should be ported to youtube, and the repair videos I could help with creating a playlist as I encounter each item
Reactions: Sota701
I am not certain which manuals you mean. If you are talking about the images and guides in this thread, these are not original Yuneec manuals or drawings. These are items provided by Forum Members and can be used freely. John was hosting a copy of the assembled document on his Website.
However, the version provided by John is out of date. It contains older links. You need to download the newest "Menu" from the first post in this thread. And always check the links before you post anything on YouTube.
The links to outside videos would need to respect the rights of the video owners.
Has anyone linked these to the forums?
Revision 06
This PDF has been extremely useful within my repairs, thank you for creating this.
Date of latest revision: 10/04/2025
Recent interest in controller conversions prompted addition of a new section in the WTFDproject table of contents. The new section is a gathering of the currently available conversions between a few of the "source-destination" combinations of the ST16 and ST16S series controllers. Use of the full guidance provided is encouraged in an effort to update the supporting files as much as possible and to clear any unknown settings or firmware that may be present.
It is important to note the ST16E is hardware incompatible with the remaining controllers in the ST16 series, None of these documents should be altered in an attempt to convert either to or from an ST16E.
Date of latest revision: 10/09/2025
Added a guide based on @h-elsner's recommendation to use QGroundControl to check the functionality of the HPlus family of drone IMUs. Using QGC makes it possible to determine basic IMU functionality without need of tools, disassembly or physical inspection.
@h-elsner provided a new section to significantly increase the information, usability and diagnostic value of QGroundControl sensor information beyond the original IMU focus.
Date of latest revision: 10/14/2025
@DoomMeister provided guidance for modification of the stock HPlus flight battery charger to allow the OEM charger to serve as an adapter to an aftermarket battery charger. The adapter makes all features of the aftermarket charger available for charging and maintenance of the H Plus Battery.
Conversations
