WAYPOINTS
If they are CCC waypoints for the H480 then read the H480 manual. If it's the waypoints from the waypoint mod read the H920+ manual.
Reactions: PatR and Ty Pilot
In a box stock Typhoon H you cannot build a mission and then fly it. You have to fly the mission, recording waypoints, then fly it again using CCC.
Here is an example of a complete mission.
Scouting the site for obstacles.
Setting waypoints.
Flying the CCC mission.
All on one battery.
Just don't set the waypoints too close to obsticals.
When flying that same CCC mission weeks later, the path may be as much as 3-4 meters different.
It's a GPS thing.
You mean using the curve cable cam?
Once the H is at the mission start point you have to raise the left stick to initiate the mission. Once the mission plan has started holding the stick up will increase speed. After the mission has completed you can fly it in reverse by pushing the left stick down.
Is that what you were wondering about?
Reactions: GILBERTO MORA
fotozone
