Why does it beep?
nir
Why does it beep?
Want can by The problem.
Beep beep beep stop beep beep
Beep beep stop beep beep .
I'm trying to upload a video but it fails.
NIR,
I am going to unplug the sensors, and the motors, each one at a time, on an old camera. Maybe I will hear "beeps" that will help us identify which two are causing the pattern you hear. Please give me about 30 minutes to experiment and write something back.
Maybe someone else has (or can find) the real beep code list for the CG03+ and can post it? That would be more reliable.
Why does it beep?
Nir,
NO codes were generated by disconnecting motors.
The attached drawing shows the beep codes I just got by disconnecting the encoders.
Here are some thoughts based on your description:
1.) "Beep beep beep stop beep beep" : IF this were reversed, it would sound like the "YAW" encoder (See "F" on drawing). Please listen again to the beep pattern on your camera.
2.) "Beep beep stop beep beep" Sounds like "Roll Encoder" See ("G" on drawing).
Since the "F" and "G" connectors are adjacent, is it possible they are reversed on your board?cgo3+ Gimbal Board Connections WITH BEEP CODES.jpg
Nir,
This drawing is an attempt to show the connections and error codes without using words that require translation.cgo3+ Gimbal Board  Connections Pictoral.png
astrologersagar
