It looks like Yuneec is still in business. I have been out of the loop for a while. Who is the current distributor in the US?
The only one I know of is Vertigo Drones. Yuneec is only selling professional models now, the days of prosumer drones like the Typhoon H and H Plus are gone except for buying used.It looks like Yuneec is still in business. I have been out of the loop for a while. Who is the current distributor in the US?
The H Plus is still on their website and the one I have in my cart at Vertigo.The only one I know of is Vertigo Drones. Yuneec is only selling professional models now, the days of prosumer drones like the Typhoon H and H Plus are gone except for buying used.
Sorry to read this, what happened? "I forgot to check the security of the second battery". What does that mean?I saw that good price at Vertigo Drones this morning.
Why you ask?
"Pilot error leads to a beautiful red, white and blue strobe display!"
While catching the local fireworks in the valley below my home last night, I forgot to check the security of the second battery on my beloved H Plus.
1) 8 minutes into the flight, I switched from angle to sport mode to run the battery down for a planned landing at 50 % .
2) However, 23 seconds later, telemetry ceased, 15.3 volts, current 69, flight mode 7, error flags 0
She went into a quiet free fall, with only the 2 landing gear mounted strobes blazing away.
I went full throttle and uttered a calm "oh no" as I watched the descent.
For a second I had hope, because I heard the motors again, they were auto rotating, and unlike the helicopter, there's no aft cyclic to cushion the landing.
She continued vertically into the heavy woods, crashed, and I heard some part rolling down the steep terrain for several seconds.
Thunderstorms were in the forecast for this morning. So last night, armed with a pair of flashlights, my iPhone with the drone scanner app for the H Plus' remote id module, leather gloves and safety specs for the thorns and densely-wooded brush, I went downhill to hunt for my favorite drone.
Using the app, it took me an hour to get within 50 meters of the remote ID . It was still broadcasting.
When I turned off the flashlight, I could see a strobe light. I'd move closer, turn off the flashlight and repeat until I found the H Plus resting against a tree. Once I was within 20 meters, the flashlight's shine would catch the reflective orange YuneecSkins decals. The OEM battery, labeled "002," was approximately 1/4 inch (7mm) dislodged from the body. The other strobe was about 5 meters to side, still flashing and attached to a detached landing gear arm. The remote ID module was about 10 meters further downhill. When I returned home, I put the 2 batteries on the dual charger to place in storage. The battery that experienced the free fall was at 74 %.
The c23 must have been the "some part rolling down the steep terrain...."
I wish I had applied the reflective decals to the c23. I searched twice today, once pre- and once post-thunderstorm, no success.
Anyway, it's great drone, if you need spare parts, batteries or another ST16s for team mode, keep an eye on this forum's classified section. I have plenty of spares, etc.
Note, I will not sell any of the parts from this freefall, I estimate it fell 80 meters.
Does anyone know if this is the first time the Remote ID has been posted as used in an actual crashed/lost drone event? Maybe on the other Forums?..... armed with a pair of flashlights, my iPhone with the drone scanner app for the H Plus' remote id module, leather gloves and safety specs for the thorns and densely-wooded brush, I went downhill to hunt for my favorite drone.
Thanks. Good question, for the 50 previous flights, "check security" is two steps for me:Sorry to read this, what happened? "I forgot to check the security of the second battery". What does that mean?
So, your battery fell out?Thanks. Good question, for the 50 previous flights, "check security" is two steps for me:
1) one hand on the front of the fuselage shell and the other hand pushing the battery, with intent, into the holder to hear the "click," or "clicks" if your ears can discern the connector and latch engagement sounds.
2) I only hear one big click, so, I check the latch release door is flush and I test the latch by grasping the side edges of the battery housing with my thumb and index and attempt to pull the battery out of the shell.
I found the battery partially dislodged, still in the drone's shell, however, backed out approximately 1/4 inch, at the crash site.So, your battery fell out?
Found the soggy c23 today, 10 July. Now drying out in large bowl of uncooked rice.I saw that good price at Vertigo Drones this morning.
Why you ask?
I find that using rice is only effective if there is very little moisture in the camera. If it's very wet I suggest a drying oven set about 125° F.Now drying out in large bowl of uncooked rice.
But you cant be sure if that is what caused the crash or the other way around.I found the battery partially dislodged, still in the drone's shell, however, backed out approximately 1/4 inch, at the crash site.
I suppose there could be some doubt. But if the battery latch is not broken, it is almost certain it was not latched.But you cant be sure if that is what caused the crash or the other way around.
Yes, I guess the battery would not come out in a crash without the latch beaking?I suppose there could be some doubt. But if the battery latch is not broken, it is almost certain it was not latched.
It is solid evidence of the cause. A partial or complete ejection of the battery verifies the battery was not locked. The only way for a battery to come loose would be a broken internal battery frame. If the battery frame is intact following a crash the battery would remained locked. Below are pics of two crashes. One shows a battery partially ejected because it wasn't latched.But you cant be sure if that is what caused the crash or the other way around.
After powering on the ST16s controller and powering on the drone (with the very same battery from my crash), I can report two things, the landing gear mechanisms have extended and the latch is still good (on the female side of the drone and even the male side of the same battery that I failed to install properly).I suppose there could be some doubt. But if the battery latch is not broken, it is almost certain it was not latched.
Drying oven is a better idea.I find that using rice is only effective if there is very little moisture in the camera. If it's very wet I suggest a drying oven set about 125° F.
