“Realsense not detected”...
Firmware is up to date on everything. Any ideas? I’ve restarted TH so many times, battery is already at 85%.
It has the sonar array on it so I assume its corresponding software is installed. I managed to fly it quite a bit today without it being on. I may very well never use it, but if it's in there, I'd like to know I can if I want to.
Sonar is not the Real Sense. It’s not clear in your post if you have the module. Real Sense is for using follow or watch me when in smart mode. It’s not a full time object avoidance module. In fact, I’ve yet to see it work on mine other then the IPS function knowing not to hit the ground when the gear is up. It’s for action selfies as far as I can tell from the videos of it in use.
Oh... I assumed there was a connection there & that it was important because the controller wouldn’t (seemingly) allow me to fly without it being active. Thanks.
The RS module replaces the standard rear status light when installed. There is a multi pin cable under the cover for adding the Real Sense module. I think once you clear that warning, it should stop coming back.
Reactions: San2C
Just to help clarify; this is a comparison between a standard Typhoon H (left) and one with RealSense fitted (right)
If you do not have the RS module installed you just have to disable a checkbox under settings to stop getting this error.
Greetings
ardigitalmedia
