Antenna truth
Hello, about to order the ITELITE DBS for the St16 on my H. Along with the dual antenna upgrade for the drone itself. Do these work? Thanks
....why waste money? I've been out 3100ft with my H pro and a solid connection all the way. At that distance it was just a spot in the blue sky. The only reason I would upgrade better peace of mind as to not loose connection.
Just my .02
That doesn't help me. I lost feed at 1,800ft out and 150ft altitude, due to trees. Hence no line of site. My question again, is does it help?
Casey,
At the top right is a search function.
Search on "Antennas" you will find all sorts of information and range testing.
I have the itelite dbs. I do not have the pro. Over Thanksgiving i flew over a lake and went over 4500ft with stock and turned around without any loss of video. Then i used the itelite and got about that far and started losing video. The itelite is so directional that if you move slightly that far out you lose video.
Bill W.
Hodgepodge
