- Joined
- Jun 11, 2018
- Messages
- 101
- Reaction score
- 25
Could it be a gun-shot, that twisted the prop ? Or a big wasp unseeable from far away... just throwing out some guesses after reading all posts.
have you convinced anyone that your prop by itself just bent and stayed bent ?
Actually, after folding his sample prop by hand he did provide ample structural evidence the prop could have bent in flight. It also could have bent at time of impact if the initial impact was at the prop location.
If the prop bent in flight it might have been responsible for inducing the vibration necessary to break other stuff.
Not same drone (weight is really different), not same motor arms, not same blades (I could bend and cut mine really easily), so not very representative!You've said it : "folding his sample prop by hand"
by hand, so there must be an external force to bend it, because as video proves it, they don't just bend during flight.
My blades don't have a proper elastic characteristic, they bend easily and don't come back.
All wood, plastic, and carbon model props deflect to some degree under a centrifugal thrust load. Full scale planes and helis do as well, which is why life cycle periods are imposed on them. That they bend or flex in flight is not in question, only the amount and amount of efficiency lost is a question. Wings on airplanes bend slightly when generating lift or experiencing gust loads. The ability to bend and return to original shape in called elastic deformation and part of the design process.
The use of cheap or soft materials can most certainly be bent under load and fail to return to the original shape under load, which is called plastic deformation, regardless of how the load is applied. All of the above is part of basic structural engineering.
All propellers are not created equal, and one brand is not representative of another. There’s even quality differences between brands of “soft” props, which used to be common fixtures on “slow flyer” type drones. The props being referenced in this thread were not designed and manufactured using a material that provides structural rigidity.
The video proves nothing relative to a prop bending in flight as at no time easy there any attempt to display blade tracking. In any case, the video is only applicable to the effects of flying with with a broken Mavic propeller in a specific configuration.
BTW, if you break the tip off of a stock H propeller it will continue to fly a lot smoother than that Mavic did. Been there, done that.
Nooo!@DronAirPro
So are you planning to purchase a new Drone, and what kind?
You tried a fly with a a stock H propeller missing its tip and it was still flying nicely (well, better than the Mavic in the video)?
This is an interesting point.
Thanks for this information.
Not sure as well if the motor pod broke because of the bent prop.I honestly do not believe the motor pod broke because of a bent prop unless it hit something. It's also possible the motor housing had a hairline crack from a previous incident.
The single most troubling thing I see in the telemetry is the voltage level. There is a significant drop during the last minute of flight before the aircraft's begins to descend. The drop from 14.6v to 14.2v is concerning. It has been my experience in reviewing logs that bad things can happen at any point below 14.4v.
From liftoff to the point of the incident was just 8:13 min during which time the voltage dropped from 16.1 to 14.1.
