Hi to all,
it as been a long time (too long) since I came on this forum.
I just saw this topic and as it is talking about me...
Yes I am the one to whom this incident happened.
I will just give the facts and no certitude as I haven't any, only possibilities:
My Typhoon H isn't new but never had crash before, even if it happened to land in high grass or in brambles twice. This was months before, I checked it after this and it then flew many hours without problem.
I check very cautiously my drone before and after every flight, that doesn't mean that I couldn't miss something wrong but I am very demanding about security!
One thing is that I bought some propellers, thinking they were original ones (I always buy original propellers) and made the mistake, yes I make some, not to verify this properly, so I flew with these non-Yuneec props.
So now, what happened:
- 3rd flight of the day:
No noticeable problem, during the shooting of a nice ancient tower near Fontainebleau (south of Paris).
Then I did a back tracking away from the tower, increasing altitude at the same time and ended with a stationary flight, until then, everything went smooth.
But then, here began the story. After a few seconds of stationary flying I eared a quite strong noise of flap, so in seconds I began to bring back home the H.
While doing this I eared a strong noise and distinctly saw an arm breaking, the H began, of course, to go mad and to fall.
Other arms broke very shortly after the first one (I couldn't say which one was the first unfortunately) and the H fell twisting to the ground where it crashed quite hard.
These are the facts !
You could see in a comment above the picture of a bend propeller with a motor and a small piece of a broken arm.
I honestly don't know if this propeller bent during the flight or when it crashed on the ground and I am surprised that a prop could bend like this and not break but it isn't because I never saw this that it can't happen. Here is the proof.
One of my thinking was that a prop (maybe this one) bent or broke in flight, causing strong vibrations that broke the arm. This arm was still attached by the wires and went to break other props and arms. This is only a possibility but...
Contrary to what has been said by someone in a comment above, I never meant this was the only real scenario.
I am open to any constructive, detailed and explained advice. I would thank anybody could help.
I must say that during this flight I didn't make any mistakes, it happens I make some and more likely I'll make some again but not this time.
I always had my H in direct view, was far above all trees or obstacles and didn't hit anything I could see (some told me, maybe a bird but in such case I really didn't see it).
I never lost connection with the drone, battery was fully charged and still (controlled) at about 50% after the crash.
Sorry for this long post but it had to be detailed.
Once again thanks to anybody could help and good and safe flights to all.
