Breeze 4k battery charger insides..
Well here's what the inside looks like and the chargers balance leads fits into a standard Hobby RC pro charge system.
I just bought a 2200mah battery have not received it yet though, do you think the breeze charger would charge this using the 4 pin connector on the inside?
Heya , I actually have a 2200mah 3s lipo pack I use in mine also , the breeze uses only 12v pins of the Stock battery , if u don't have a multi meter they are the two end ones the one that is up and down is the positive. The two center pins are not used on the breeze itself on the stock battery that is for the charger only , it allows the battery to balance charge the batteries, so u don't have to worry about all four to make that battery work and it will work I have flown mine many times with the pack in the pic below.
So inside the breeze it only uses the two outer pins of the battery , I'll take a pic I'm actually working one two right now of what the inside connector looks like .
That's what it looks like in the last pic it's lined up like that under that board on the drone below it u can run wires off of those posts on the back of the battery terminal inside the drone to the back , I fly mine just like it is in the first pic and it works fine didn't even have to trim it out for the weight difference it auto adjusted power and stayed just like always and had plenty of power , u can tell the first 5 mins of running it's a little more punchier than with the regular 1100mah.
I can get u any pics or any other questions feel free to ask .
Gotta post up some video of the flight when u get it going .
fabricolaundry
