Camera Tilt
Should the camera be able to point straight down on the st16 controller, it seems to not be pointing straight at the ground, I have adjusted the A03and K2 to 7 seconds to slow the tilt down, is there a way to adjust so camera can point straight down?.
That is where I set my tilt speed from the 10ms to 7s and it is slower and smoother to control
When I pan the camera slider to the full down position it will go straight all the way down sometimes, then others it does not point straight down, I then push slider to full up then to full down position then this time the camera points straight down ????
Take a look at the slider in Hardware Monitor and see how it responds. I have seen other posts where people have said they have to apply a bit of pressure at the bottom of travel to get it down. It could be a sticky potentiometer.
Yeah that seems to be what happens I need to add a bit more pressure holding it down or move up a bit and slide it back a little firmer,never notice it before flying just when it is on the work bench.
apalomba
