Cant update firmware to H and cgo3 ?
updated firmware to st16 with no problems, tried to update to H and cgo3 and can get it to the step
where it says - Step (1-2) fiirmware is decompressing please wait , the after awhile passes says -
Camera response error- time out
anyone have this problem ?
After updating your ST16 the CGO3+ needs a new binding.
The Update-File is only: TyphoonH_Ver2.21_A.bin
not TyphoonH_Ver2.21_A.zip or TyphoonH_Ver2.21_A or an unzipped folder.
Try to use the untouched original SD-Card which was included with your typhoon-H-package for updating your copter and CGO3+.
chris i had the same issue, i just downloaded the file again from yuneec and it installed as it should.
Thanks, just changed the file name to have bin at the end and that worked :)
I had to download it in Google chrome.
I noticed this...When I tried to update the ST-16 I kept getting update not found. I tried re-downloading. Nope. I tried changing the file format to .bin. Nada. THEN I tried changing the format of the micro SD from ExFat to MS Dos. BINGO!!! Probably good all around to set them to MS Dos.
For some reason I get a step 3 indication which makes it impossible to update . Yuneec UK will no doubt sort it out
Ludwig
