Changing blades
Anyone know what size Allen wrench to use when changing blades? I’ve got hundreds of them, but none fit. Tia!
1.5mm hex. See page 10 of the attached guide.
  • Breeze Disassembly Guide.pdf
Hi from Egypt,
happy to find someone else flying Breeze. i am stuck with the Breeze App not connecting to my drone. is your app working and communicating with your Breeze drone?
Hello from Egypt,
I saw you helped with the guide. i have a problem with my Breeze App not communicating with the drone. it was for the last couple of years since i baught Breeze drone in Vancouver - Canada, but all of a sudden it stopped working as of 1 April 21. can you help me too?
Hello from Egypt,
Are you using the Android or iOS version of the Breeze Cam app?
Hello from Egypt,
AHG, I was having that same problem, but had to update my app. Let me try to find the link for you....
Couldn’t find the link, but the attached pics are what I did.
Step 1. Open App,obviously.
Step 2. Click top left “menu” button.
Step 3. Click on the About tab, which is an circle with an i in it.
Step 4. Click on Firmware Upgrade which should be in the center of the screen.
Step 5. Click the “Look for available updates” box.
Apparently, my phone sucks and slips out of the app and back to my main screen when I do this. But if I do it a few times, then go back into the app, I’m updated and ready to go. The other guys around here are MUCH better in deciphering problems and issues, just telling you what I did to fix my issue.
dharminder
