i have same issue.
any ideas?
edit- re-install has made no difference. map picture doesn't load exactly as per your issue.
I have the same problem, no maps, connected to wifi and internet, all apps works (Google Maps, web browsing ...)
Very nice app, thanks a lot. Too bad maps does not work for me though.
Below some info that might be of interest if someone else also have the same problem or can figure out what I´m doing wrong.
For my ST16, I have Build number: st16_system_v03.01.b22 & Kernel version 3.10.20
Under Program icon in the green Pad main window, tap "Settings", "Location", Location is on
(the upper right corner should display "ON"), and it states "Mode High accuracy"
Uninstalled flight center, and installed it again. Have rebooted several times.
Have done a reset to factory settings on the ST16 and installed flight center again and no difference, still no maps in Flight Center.
(have restored/copied back all folders/subfolders and containing files after factory reset, FlightLog, Flightmode and so on)
The banner at the bottom of the main screen is green and says I´m online.
Original firmware was E and updated to A version when the new firmware version became available. I´m in Sweden.
Any suggestions ?
