So I'm out doing some portfolio shots this morning and on my way downtown to pick up some stuff I'm driving through the "country" and pass by a couple of fairly large new homes under construction. Standing out front of one of them is a group of people so I figure, "what the heck, the worst they can do is say no". I stop and check with the homeowner to see if I can do some aerial shots using a "drone". No problem she says. She wanders back to the group so I head there next to give her a business card. While walking up to the group I hear one of the men in the group call me by name. Who's that I wonder? As I get a little closer one of the gentlemen standing there is the CEO of a major UAV company, yes, they know multirotors, and.... it's my boss. I'm thinking it just won't look very good to back out now, and this is not a good time to encounter any problems. Do it well and no grief should come of it, do it badly and I could be retiring a lot sooner than May.
So, set up, pre-flight with extreme care, wait for satellites, get in an advantageous sight line position. Satellite count for the -16 comes up slow. 8-10-11. 15 on the bird. Could be better for the -16 but it should be good enough. I do wonder why the =16 count is coming up so slow but I wasn't all that concerned. So I lean against a rather tall fire hydrant and get comfortable. Hover about 10' off the ground, 20' out and set up the shutter speed and EV. Go for the first shot location, raise the gear... compass error warning, instructed to land in Angle mode immediately. The H is in about a 5mph drift straight ahead. No problem, I was already in Angle so speed slider down and just drive it where I want it to go. Lower the gear and start a return, move away from the fire hydrant. Compass warning goes away and positioning again becomes rock solid. Left the gear down for the remainder of the flight. Finish the shoot with nobody the wiser.
What caused the compass error? Good question. Was it the tall fire hydrant I was leaning against? What is the gear retraction? Was it just a random event? Yesterday I had the H sitting between fence posts on a table located in the middle an open chain link fence gate working with ISO, shutter speeds and EV to develop a good feel for what worked with changing light conditions. No intention of flying so I wasn't concerned about interference from the fence. I did observe that every time the wind blew the gate shut where it came between the H and the ST-16 it would generate a compass error. What's somewhat odd is this morning I was doing some inspection work of an overhead loading chute and had no compass issues at all, and the H got pretty darn close to a lot of metal pipe and railing.
Moral of the story, use Angle mode whenever you can. If you get a compass error warning, take control of the situation. Assume you've lost GPS as well. Expect the aircraft to start drifting. DO NOT use RTH or Smart mode during a compass error. Reduce the speed and bring it home. If the H was in Smart mode, get on the switch as fast as you can because the H may start moving out pretty fast. Despite crappy lighting and the compass error it was a pretty good day.
