Ok guys... Dramas updating the H.
This pic is all that happens. Clean formatted card with only the H file on it. As soon as I press the update button this happens, press ok and it goes back to flight mode. Any ideas?
Sent from my iPad using Tapatalk
It's the actual H I'm having trouble with Wes, not the ST16?
I had a different issue with my update. Spoke with Yuneec Customer Service and they said you need to use a Class 10 card. Has to do with the way the ST16 and H read and process the data! Plus you need to use Chrome browser also.Yes. Tried everything... Even went out and bought a brand new Class 4 U3 card this morning and still the same problem.
Sent from my iPad using Tapatalk HD
Hope this helps.
Sorry guys...Typo. Definitely Class10 U3 card.
Typhoon H STD V2.21A from the USA site.
Tried at work this morning, Formatted fat 32, downloaded thru Chrome... Same result... Am running out of ideas and patience.
Anyone in Adelaide South Australia with a Typhoon I can talk to?
looks like australia and new zeland have special firmware
thx needed to remove it and add again V2.21 is replaced with this one
please delete wrong link from quote msg
The Typhoon is picky about what type of memory card it uses. I have a 128Gb Snadisk Extreme card that I like to use, but the H wouldn't do the firmware update while using the card. I swapped it out to the 16Gb card that came with the H and it worked just fine.Sorry guys...Typo. Definitely Class10 U3 card.
