HELP TYPHOON H CRASHED FROM 250FT UP
Hello,
This is real Chinese for me, I just can't figure out what all those numbers means, I wish I could have some instructions on how to interpret those darn telemetry. Where is that "error code column" and what is that 32s means? Thanks for your help
Lol you and I are in the I've been trying to understand what the Telemetry means and finally I figured out that code 32 is a calibration error and is in the second to last column in my fly log that column is considered the error column I guess. My drone dropped outta the sky and smashed 3 days ago unfortunately
So I'm learning as I go about this whole lot thing. But if you type in Google search fly log error codes for yuneec you should see what all the numbers mean. I read on another forum that there has been a common calibration issue causing fly aways and the drone to drop outta the sky.
Hello,
If you import the telemetry file into a spreadsheet (using comma as the delimeter) you will see the numbers in columns. The column called f-mode is useful as it shows what flight mode the H is in. Your file shows 'Ready to Start(16)' followed by 'Smart mode - Follow(21)' followed by 'Go Home(13)' then 'Landing(14)' and finally 'Emergency motors killed(12)'. Also at 13:50:56:633 there was a motor fail at a height of 9 meters - could this be when it tried to land in a tree?
Go to Meine private Homepage - Programmierung, Kopter, Bilder to find an excellent manual on the telemetry.
Hope this helps you understand what happened.
Axel66
