Lume Cubes for the H
I think I've found a solution that will work on the cubes with RS installed. Check out the clamp on Amazon. Attaching this clip to the land gear should work just fine. Comments are welcome.
Foto4easy Heavy Duty C Clamp U Clip Type Bracket with 1/4" Screw Mount Studio Stand Lighting
So.... don't try these. Here's what i found, 1 - They weighed a little bit more than i anticipated. the extra weight will surely drain battery faster. 2- The only place to attach to is the landing gear. Well when the landing gear retracts, the cubes will come in contact with the props. What will work is using a rotary tool to file down the back edges on the cube adapter to a point where it will slide on. It has to be filed down enough to get past the antenna wires and landing gear.
Alvaro
