Mounting GPS?
Hey can someone tell me which way the GPS is mounted, Wire to the front are wire to the back?
There is no arrow on the PCB?
As I can see in the pictures, on the PCB is the GPS only, so direction doesn't matter.
Reactions: Gunit
Probably yes.
What is on this IC marked?
You can see a module from H480, there is a compass... Just a second I did a topic with questions about these modules.
Reactions: Gunit
All of the other Hex series from Yuneec have the wires at the rear of the aircraft. I would suspect the 920 series is the same.
Patynowy
