People can now watch clips like this to kill our birds...
What a prat.... too much time on is hands... what happen's when he misses?People can now watch clips like this to kill our birds...
Probably wrap that net around some child's neck. I wonder how many 'takes' it took to show it hitting the aircraft. I do agree with earlier comments, though. Anyone flying so close deserves to be taken out.What a prat.... too much time on is hands... what happen's when he misses?
I suggest you check how much you are going to lose if you take a drone out of the sky.
The FAA considers a drone as an aircraft. There is no difference in taking down a drone to taking down a plane or a helicopter. The FAA says its a $250000 fine and up to 5 years in prison for taking down a drone.
As a side note, when you buy a house you dont purchase the airspace above it. You purchase the land area (lenght x width), you are given the dimensions in square feet, not in cubic feet.
So, my suggestion is put that thing back in the closet cause the day you run into an angry drone pilot you will regret to have purchased or built that thing.
Some people have FAR too much time on their hands. Very clever idea, however, all he had to do was to just close the door to his shed.
John Taylor was claiming that under Part 48 no model aircraft was required to have a registration and he won. However, that only applies to drones used for private purposes. Those used for commercial purposes are still required to have an aircraft registration number, therefore are and will continue to be considered "Aircraft". I am checking right now the court documents and it explicitly says "This ruling does NOT apply to commercial or public aircraft". So, if you take down a drone that is being used as a hobby, congratulations!, BUT if you are unlucky enough to take down one that's being used commercially, oh boy you have a problem!
Since you can't see farther than 100ft away if the drone has a registration number or not, why risk it?
If you want to take drones down using this Net Catching System, you will face charges as per the court ruling previously mentioned. AND, if you decide to go the extra mile and pull out your .45cal or 12 gauge shootgun and blast it out of the sky, you will face way more serious federal charges which include, but are not limited to Shooting ammo to the air without a safety reason, shooting down a registered aircraft flying in FAA Airspace. among others they might come up with.
In most states shooting bullets to the air is just that... illegal.
Have you heard all bullets come down?
There is a LOT more to lose than to earn in this case.
One is commercial use and the others recreational. If anyone takes the part 107 test they will understand the dos and donts of this hobby.
Look up the word "elegant":I was told by a senior engineer once that all solutions must be "elegant". A year later he didn't work there any more. Closing the door would not be elegant.
