RealSense IPS Module?
mw6
A question: is it possible to enter IPS mode without the RealSense module and without GPS (to fly indoor)? Thanks.
A related question: is it possible to enter IPS mode without the RealSense module and without GPS (to fly indoor)? Thanks.
I believe it is required that you have the RS module installed. There's no other way for the system to determine 3D object position as ultrasonic sonar is very imprecise.
Reactions: WTFDproject
Is IPS module sold separately from the RealSense module, or it's part of the RealSense module?
here it says: Realsense and IPS modules as two separate units?
And according to this link: they are two separate modules but always sold together?
here YUNTYHIPS is sold separately?
I found this doc:
On page 4, it shows
-- YUNTYHR RealSense for TYPHOON H
-- YUNTYHIPS 1 pc of IPS(Indoor PositioningSystem(for TYPHOON H)
are two different modules, so you may want to check your drone has YUNTYHIPS? see the attached images.
Reactions: DoomMeister
Yes, I have both components. I can not separate them. They detach as a single module.
Do you mind post a photo (I can not separate them)?
So the IPS and RealSense module are always sold together?
I want to purchase IPS only, but looks like I can only find RealSense module sellers on EBay.
I have never seen that in North America. It may have been an option in the European market.
Thank you for the doc. very interesting, My H have two units, IPS mounted underneath and have a RealSense unit mounted in front
Please take a photo of yours and upload here. Would be interesting to see them as separate units.
I bought my H Pro as a complete unit so I have removed the camera and realised my statement was incorrect, my apologises for this it's a complete module and not separate
AS previously stated that mine Realsense and IPS units are separate (Not correct) they are one unit I have tested my H and the IPS sign will display right hand top of the screen, ONLY when the motors are running
Rank Li
