I believe it is required that you have the RS module installed. There's no other way for the system to determine 3D object position as ultrasonic sonar is very imprecise.A related question: is it possible to enter IPS mode without the RealSense module and without GPS (to fly indoor)? Thanks.
Is IPS module sold separately from the RealSense module, or it's part of the RealSense module?I believe it is required that you have the RS module installed. There's no other way for the system to determine 3D object position as ultrasonic sonar is very imprecise.
Yes, I have both components. I can not separate them. They detach as a single module.I found this doc:
On page 4, it shows
-- YUNTYHR RealSense for TYPHOON H
-- YUNTYHIPS 1 pc of IPS(Indoor PositioningSystem(for TYPHOON H)
are two different modules, so you may want to check your drone has YUNTYHIPS? see the attached images.
Mine one, which is working.I found this doc:
On page 4, it shows
I have never seen that in North America. It may have been an option in the European market.Do you mind post a photo (I can not separate them)?
So the IPS and RealSense module are always sold together?
I want to purchase IPS only, but looks like I can only find RealSense module sellers on EBay.
That's good to know. So just want to confirm: in US all the RealSense module include the IPS module?I have never seen that in North America. It may have been an option in the European market.
The IPS module is a spare part for the RS module as such. You cannot use it alone without make a complete new autopilot firmware for FC.So the IPS and RealSense module are always sold together?
Thank you for the doc. very interesting, My H have two units, IPS mounted underneath and have a RealSense unit mounted in frontYes, I have both components. I can not separate them. They detach as a single module.
Please take a photo of yours and upload here. Would be interesting to see them as separate units.Thank you for the doc. very interesting, My H have two units, IPS mounted underneath and have a RealSense unit mounted in front
AS previously stated that mine Realsense and IPS units are separate (Not correct) they are one unit I have tested my H and the IPS sign will display right hand top of the screen, ONLY when the motors are runningDo you mind post a photo (I can not separate them)?
