BE EXTRA CAREFUL OF THAT SWITCH ON THE RIGHT ! ! !
The battery was low and I was planning a hand catch.
I positioned my left hand on the red button.
As I let go with my right hand to reach out, I accidentally bumped the mode switch.
I grabbed the H just as is responded to "Safe" mode.
The H went to full power to back up 28 ft.
The watts load at low volts drew high amps from the stock battery.
When I pulled out the battery, the inside of the H smelled really bad.
The H would no longer power up. The main board was dead.
I had to swap out the main board.
This is a slow motion view if the incident:
