And you mean moving the right "Stick", not gimbal, correct!"Disappearing over a reasonably away tree line" is an euphemistic attempt to say I was flying further away from LOS than I wanted to report. No self incrimination!!!
I wish I could say it wasn't so, but I feel this is the only answer to how the arrow pointed at the controller and flew towards me, with forward stick movement, but I will check it out today and verify!A few times I have lost sight of the H and become disoriented when it disappeared over a reasonably away tree line. Moving the right gimbal in the direction of the point of the green arrow has always brought it humming right to me ( and not using RTH). So now you have me worried DC... I have to factor in a bump or switch position may result in this rule being invalid? Say it isn't so!
Yes. My bad.And you mean moving the right "Stick", not gimbal, correct!
No problem! I am just confused until I fly later today, as I always had the stick towards the arrow point brought me home, but yesterday, while flying back forward to home, the arrow pointed to home, but I was pushing forward on the stick, away from the arrow point to fly it towards home, Never did that before and wonder if the Pan Stick affects that at all? Will testYes. My bad.
Dos Equis my friend ! Stay Thirsty My Friend! LOL !To many Coronas D.C.
Good post. Like DC, I'm completely lost on using the goofy green arrow. My brain just would not process whatever I read about it. Having flown the Phantoms so long, it's like learning a new language! But your post explained it in a way I finally got it. Thanks!Try it again DC. Put the H or Q (both the same for green arrow) out about 200' When you do a slow yaw, the green arrow will rotate. When it's pointed straight up, the nose is facing you. When the arrow points down, the nose is facing away from you. And yes, moving the right stick in the direction of the arrow will bring it home.
Well I run mine out straight away and the arrow points at me,just like my other Yuneecs. So if I spin it around fully to where arrow points away it comes back exactly the same course. The arrow does reference which way your H is pointing,just that it works the opposite way your used to an arrow representing.The GREEN arrow points in the direction to move the RIGHT stick to bring the H back towards your location. It has nothing do do with indicating the direction the H is pointed. I have noticed it is only accurate if the H is 20 feet or more away from me.
Green arrow points left, then move the right stick left and she will come back.
I would rather it tell me the direction the nose is pointed. Well it kinda does.
Did I Confuse even more?
I will call you and explain D.C.I wish I could say it wasn't so, but I feel this is the only answer to how the arrow pointed at the controller and flew towards me, with forward stick movement, but I will check it out today and verify!
