TH firmware update problem
No mine bricked so bad they sent me a RA tag
arrives in Cali Monday, Im not too thrilled the 3.0 firmware caps us at 400 ft
as I can fly Higher at my AMA field than 400 ft
I'm really considering selling The Typhoon H and going with the DJI 4 Pro or Mavic
You may want to go read the Mavicpilots and Phantompilots forums. Also check the threads on RCGroups.
If anyone else has this problem let me know and I can send on the email I got from tech support in the UK with the relevant firmware and instructions on how to resurrect your TH if it bricks
Hi Steve.
Please send me the firmware you got from tech support. I have the same problem
[Quote = "Steve Wall Morris, post: 36066, medlem: 3705"] Hvis nogen andre har dette problem så lad mig det vide og jeg kan sende på email jeg fik fra teknisk support i Storbritannien med den relevante firmware og vejledning om, hvordan man genoplive din TH hvis det mursten [/ quote]
Hej Steve. Jeg har dette problem også. Send mig venligst den firmware, so I can get out to fly again.
Best regards from [email protected]
There is no restrictions with the latest and well working firmware. You are misinformed.
maahdevbook
