Typhoon H antenna question
Which is best to use. And what is the difference 20190721_180300.jpeg20190721_180306.jpeg
Here is one of the numerous threads where this question has been answered. Site search is your friend...
Reactions: Chevyfreke
Thanks for the info it was very helpful
Reactions: RatBob
The flat antenna gives better video range but is highly directional...The flat part needs to be pointed at the aircraft. The mushroom antenna doesn't give as much range but you don't need to point it at the aircraft...you point it upwards.
Thank you very much for explaining it to me so that I understand
gocdunn
