Do it again and discharged it to 14.4v that's when the typhoon will auto land. That will be the usable capacity for the H. You should not discharge it below 14.2v or you can cause damage.
You discharged to 13 volts???
Don't know where you get that "rule", but in my years with using LiPo's and hanging around with my other piston-head brethren the general consensus is to never let the cell voltage drop to 3.3v or below. You're living on the edge there, son.Yes, it's a 4 cell battery and the rule is to never discharge below 3 volts per cell so 13 volts is 3.25 volts per cell. Normal new battery packs that I have tested may go 100 mah over the rating but I was shocked to see over 7000 mah out of these that are rated at 5400 mah. My charge cutoff is 16.8 volts.
It took 102 minutes to discharge at 5.0 amps (1C) and I am suspecting the Typhoon is discharging at (at least) over 10 amps (2C+) so the capacity will be slightly less at that rate. NTL in my comparison with other similar capacity packs I have tested over the years these packs from Yuneec seem to be amazing!!!
