Thought I sent this out a week ago but I don't find it or help replies here anywhere.
Both H systems are identical
ST16 system_v03.01.b30 app_v01.00.45
Aircraft:
Autopilot v1.35
Gimbal v1.25
Camera v3.2.343 A
REalSenseN/A
Been flying an H since they first came out. I had 2 for business purposes til my original H power dove into the ground during a pre client test flight. Now I'm having a problem with my backup H. Had been flying on assignment for about 4 hrs. with no problems at all when I lost almost all movement control with my right stick - mode 2 - and yes I checked all of my control settings including throttle. Everything was set normally and I was able to land without a problem. Since this is my first problem with this H I'm anxious to find a solution. I've done a complete re-calibration, including compass, read through the manual, read posts here and haven't found a solution yet. So here I am asking for help from my experts on line. I didn't know if it was a mechanical or software problem and still don't, but what I do know is that I swapped out my st16 and tried using my other one for the crashed H, and did a full re_calibration, binding etc it is a YES and it works perfectly.
This brings my thinking to the likelihood that it's probably a mechanical problem with the right stick and replacing it would solve my problem but I'd like some guidance here before I buy a replacement. I'd appreciate any/all input from my online flight crew before I proceed. Any thoughts will be appreciated.
I sure hope this goes out this time. Thanks in advance.
Aircraft:
Autopilot v1.35
Gimbal v1.25
Camera v3.2.343 A
REalSenseN/A
