typhoon h problem, need help
Hello,
Try this:
- Switch on ST16, tap "model select", OK to accept pop-up, etc..
- Use "COPY"
- Long press the model you wish to copy and tap "copy"
- Rename (typhoon 2 or whatever..) the newly created copy, so not to conflict with original.
- Perform steps to BIND to the new aircraft.
This can works...
Good luck!!
It has to be the GPS. Maybe you can try it with the GPS unplugged and switched off on the ST-16. Might be that the broken GPS is giving off a signal to the flight controller which is not recognized by the FC causing it to error.
Can’t say for sure that will work but it might help.
Hi, I have the same problem, I think the gps module is broken or something, but what I do is: turn on the bird and wait about 10 or 15 min, to "preheat" the gps module, and then calibrate the Accelerometer, and then the gps go on. You can try restarting before calibrating the accelerometer. Its a trick I have found, but the thing is that you have to wait those minutes. I don't know how to change the gps module or repair it. Hope it works. Regards from Mexico.
Frida Gold
