I just got the typhoon h a couple weeks ago and there's so many things to learn, number one is do I need to bind the aircraft and the other what about updates do I need to update it
The pairs are shipped already bound together. Personally I would only charge both batteries, put a card in the camera, and see if the thing will get in the air.
After the ST16 is on, turn on the TH, then wait till you get cam pic and enough GPS Sats to make the TH rear light be solid purple with white flashes, solid purple being the craft and white flashes being the ST16. May need to wait 5 minutes or so. Be patient. Study all the readouts on the ST16 while you wait.
The TH voltage in the upper left corner you'll want to check while you fly. Have the craft landed before that flying voltage drops below 14.5. Taking off is easy. Take your time landing, go slow, when it touches down, keep the left stick straight back till the motors rev down, return stick to middle and hold the Red button down till the props stop, then release.
Starting that first flight, if you get warnings about Compass calibration, land again and follow the written instructions for the 3 calibrations.
The compass cal is much easier if you first slide the camera (gimbal) forward and off. Press a release under there while pulling forward.
Warnings or whatever that clog the screen can be quickly removed by tapping the go-back button, lower right. If you take a test video, stop it before you turn off the TH. Cam buttons: press once quickly, don't hold them down.
Happy flying to you...
