Typhoon H ?
Hi guys and gals..
I have recently purchased a typhoon H, it has a.broken arm and gimble. The guy i bought it off claims it's a "H" but it has real sense fillted!. I was under the understanding that the "H plus" came with real senses?
Is there a serial number or a way to check so i can order the correct arm assembly.
And for any Aussies can anyone recommend a repairer in Queensland?
Thank in advance
Reactions: SkyVidTek
The Typhoon H with Realsense was called H-Pro. The H Plus is a different machine that uses a lot of similar parts.
If the camera is a black CG03+, you have an H-Pro. If you had an H Plus, the camera would be a silver C23, and the label on the nose of the craft would have the word "Plus" added to it.
Yuneec Drones Australia has a map feature showing some dealers and possibly some repair facilities. Try this link:
marcojanson67
