Yes, and I really like the colours in the sky, which so often looks washed out.the opening of the lens (or rather the sensor) is well managed with the sun in front
But I'm seeing some stuttering in the video as though the SD card isn't capable of writing it to disk fast enough - especially in the faster, low altitude sequence across the water.
At faster drone speeds, and when panning, the capture system is under maximum stress because each frame is so much different to the preceding frame and therefore the amount of new data to be written is so much greater. At slow speeds, everything seems to work fine because the number of new pixels in each frame is much smaller.
I would be wondering again about the capabilities of the SD card being used; but this video is a Yuneec distributor production, presumably using the card supplied with the H Plus - or at least one which they think is up to the task.
Having noticed this issue on a few of my favourite H Plus videos, I'm starting to think that I shouldn't purchase until there's a cure.
