What's with the clock
I set the correct time and when I go back to the flight screen it's an hour behind.
No daylight saving time
I had the same problem over and over, Here is what fixed it. Set the time again, do not exit that screen, just turn the power off the ST16
then power on it should be the correct time..
Just tried that and it worked a treat. Thanks for the tip
How about that, you the man! Got the right time on pilot screen now.
I've done this and it works, but only until the next time you enter pad and then go back to FlightMode. :mad: The only time it sticks is if you power off while in pad mode. WTH?
I just placed the fix for this problem, on another thread, a few minutes ago. Under, Typhoon H Camera timestamp
gbare
