PatR
Premium Pilot
Let’s go back to the first post for a moment.
Have you tried removing and re-installing the gimbal? Doing so helps to assure it’s correctly mounted.
Firmware was mentioned. What firmware is currently loaded in the system? Tap “Settings” on the ST-16 with the aircraft turned on. Then tap “About Controller”. That will cause the ST-16 to display loaded firmware. If no firmware shows for aircraft or camera it indicates lack of bind or no connectivity. Bind is usually the issue.
Come back and let us know what you find before going further.
