480 or 520?
I was watching & searching charger & battery info, and realized the 520 is orange, did it ever come as the gun metal grey & black?
Just measured mine, 480 from motor to motor,,,,,,,,,,
Have I been posting in the incorrect forum?
Oh man, no wonder there was some confusion, sorry .
Do it this way:
If it's gray and has a CGo3+, it's a Typhoon H (480)
If it's gray and has a C23, It's an H Plus
If it's orange and has an E90, It's an H520.
Unless it's not standard.
Reactions: Thunder horse
I see you've added to your original post, I'm sure a moderator will put it into the appropriate section.
Do it this way:
Covered in a skin.
Do it this way:
Greetings: Doesn't the model number or serial number give insight to this issue??
A simple measurement from motor center to motor center 480mm or 520mm
osttopstconverter
