"A" motor - props don't fit
hello - props work ok w/"B" motors. tried multiple props on "A" motors. none work - any ideas?
I assume you are using "A" props on the "A" motors?
If you are using the inexpensive aftermarket props, it is not uncommon for them to be so poorly made they will not even go on. Even if they do, it is not a good idea. The balance is almost always terrible, and they have a history of breaking while in flight.
Do you have A props and B props to put on each prospective motor type? A props screw on in a CCW direction and B props screw on in a CW direction. See page 9 in the attached User Manual.
  • q500_4k_user_manual.pdf
"B" props went on ok. Not sure about the props could be 3rd party.
Rank Li
