I'll look. Some where positive value changes and some were negative.
Now tackling the tilt takes a few more steps. Again, enter Channel Settings and hit ok to exit flight controls. Tap the A03 box that highlights the K2 box on the left. Tap that box which brings up the tilt slider pitch curves. Note when you flip your S1 switch between the three positions that the pitch curve screens are following that switch.
I set my angle mode position to lower the camera down a bit to make a more even default horizon to foreground position when the tilt slider is fully up. This requires editing the curve found in this switch position. The rates are the absolute travel value here so by lowering them to -75/+75% you will limit the total tilt roll in this switch position only. I also added an Expo of +28% to change speed behavior and made this my most responsive position.
Now flip the switch to the middle position to gain some function here. With this one, I left the rate at 100% but added an 18% positive expo. This will make more sense when done so onto the last position.
The 3rd position or velocity mode behaves differently already then the other two when it comes to tilt speed and end points. It bugged me that the fully up position caught to much drone in the shot. By lowering the travel rate to 84%, you can stop it from passing the most annoying angle (note forward quick flight or wind can still pop a motor pod into shot but it's less often and never in hover) it came with. This I also did a negative expo of -37% which makes for a very slow roll when close to middle beep point.
Here are the screen shots of the three switch positions.
If someone can't translate them to English in the next couple of weeks I will do so when I visit a German friend of mine in May.
Super THANKS We always fly in team mode with 2 ST-16 controls this is a major GAME CHANGER !!
Hi Craig, sounds like you did a lot of work there. I'd be interested in paying you for a video tutorial on how you changed your switches. That's my only beef with the H - the gains on the gimbal knobs and sliders are so high as to make fine tuning a challenge. And with no dynamic braking on the gimbal, often it rotates past where I need it. Hang ten, man!I could be wrong but the 10ms is for the time it takes to start signal from the center/off neutral position. I recall when playing with this value that it only delayed when my tilt or pan started moving. The speed of rotation is controlled by the knobs position relative to distance rotated. At its extremes, it rotates very quickly as we all know. By changing the ms value to secs, you are delaying the start time so when you twist the knob to initiate movement, it will take that 3 secs before moving. This allows you to place the knob in slow moving position like 1:00 for right pan, and 3 secs later it moves at your preset speed consistently. Same holds true for tilt slider as it also has a neutral position. The speed is actually set by the pitch curves hence the expo shaping to control tilt position angles as well as speed.
