Yes I turn it on in hand, just cleaned them as there was a finger print in the large one ? We'll see after a couple of busy H+ days thursday, and saturdayDo you turn the Breeze on then set it down?
The other thing to check is that the IR sensor filter is clean on both the inside and outside.
Thanx, another class under my belt, I'm slowly getting this stuff retaining is the hard part, but gettin there ?You really should set the Breeze on the ground in its launch position before turning it on ( the more level, the better ). Part of the initialization routine records the position of the IMU sensors. I have found flights to be more stable when I do that.
