Altitude ?
Do you turn the Breeze on then set it down?
The other thing to check is that the IR sensor filter is clean on both the inside and outside.
Yes I turn it on in hand, just cleaned them as there was a finger print in the large one ? We'll see after a couple of busy H+ days thursday, and saturday
You really should set the Breeze on the ground in its launch position before turning it on ( the more level, the better ). Part of the initialization routine records the position of the IMU sensors. I have found flights to be more stable when I do that.
Thanx, another class under my belt, I'm slowly getting this stuff retaining is the hard part, but gettin there ?
nubestpremiumsupplements
