anyone has dismantled mantis q
Guadeloupe
nobody has to dismount mantis q ?? I pay 600 euros for mantis after one flight one crash. I cant having the firmware by yuneec europe ,no one can copy me this firmware that is in the micro sd same in the pict below, thanks to the one who will copy the firmware for me
So you’re trying to change firmware while making repairs to your crashed MantisQ?
Hi moms, there is no firmware in the internal micro sd.
I had a look to the internals of this little wonder, I disassembled my Mantis Q after giving a look to FCC ID 2ACS5-YUNMQA Mantis Q by Yuneec Technology Co., Limited in 2ACS5-YUNMQA_Internal Photo
This is the contents of the internal card:
Code:
/fs/microsd:
    log/
    params
    dataman
    bootlog.txt
    logdata.txt
    /fs/microsd/log:
        sess001/
        sess002/
        /fs/microsd/log/sess001:
            log001.ulg
        /fs/microsd/log/sess002:
            log001.ulg
As you can see, there are only logs and present parameters files. If card is empty, it restores them with default values, that can be modified whith the App.
First time I turned it on, it updated the firmware, and later I found on my phone, under YuneecPilot\Upgrade, two files:
MANTIS_C21_E_1.1.06_BUILD1473_20190130.yuneec
MANTIS_CONTROLLER_1.1.06_BUILD1473_20190130.yuneec
They are zip files, the contents of the first one is:
15685
and the second:
15686
And finally, I found in one of the onboard cards, I don't remenber if it was the internal or the external, two files uploaded to the Mantis Q from the controller:
autopilot.yuneec.updated
opticalflow.yuneec.updated
All of them are EU firmware, as the versioninfo.json contents:
Code:
"project_name": "MANTIS",
"camera_name": "C21",
"wifi_band": "E",
"version": "1.1.06",
"build_num": 1473,
"build_time": 20190130
If you need any of this files, I could upload them for you. If you need US firmware, may be another user could find them on his phone.
Sacha
