Anyone obtained or tried a C23 on a Typhoon H yet?
I wonder how it will work if there is no firmware update for the ST16. The C23 won't appear as a selection until then. Perhaps it will work as a CGO3+.
Reactions: PatR
I'm hopeful the firmware will be available for the ST16 to allow the C23 to connect. That would allow the camera to be compatible with both the H and the H Plus. However, I am concerned Yuneec will offer a C23 with firmware which will only work with the H. So if you have an H and an H Plus you would need two cameras.
I can connect to the wifi of the C23 in Pad mode but not in Flight Mode.
Perhaps overly cautious, but a word of advice;
Do not allow history to repeat itself. Regardless of how well the C-23 camera performs on the H Plus, do not buy a C-23 hoping it will later work on an H-480 after a firmware upgrade. It was not that long ago some bought H-480 CGO-ET’s to use on their 580’s. That did not work out well. Let Yuneec first prove the C-23 to be backwards compatible before making a purchase decision.
Wise words and my plan. Once bitten ........
Just FYI.... Yuneec UK lists 2 part numbers for the C23
C23 for Typhoon H Plus: YUNC23EU / C23 for Typhoon H: YUNTYHC23EU
Just spoke with Yuneec UK about the C23.
The first batch will be H plus only but the H version they hope to have in by the end of the month (I assume thats Yuneec China end of the month so probably February ;) )
Anyway the H version they believe will also work on the H920+ (subject to testing when they arrive) and obviously using the CGO3+ adaptor.
If this is indeed the case then I expect I will be tempted into purchasing one. Then just need the C23 with a longer focal length ;)
I found a post from the dealer in Australia who says the C23 for the H is labeled C23H. In other words, the firmware is different so like the CGO-ET there will be two camera models that will not be interchangeable.
I tried the CGO-ET on the H Plus and the ST16 does not find the camera signal. I'm left wondering if the -ET for the 520 works with this model. In any case, I'm disappointed the -ET doesn't work, at least not yet.
jinheng
