Battery charging plug for H520
Because of the scarcity of the LiHV charge cables, I decided to make my own. I created a Solidworks model of the case halves and printed them in ABS. Photo is of first attempt, 3 more are in progress. Rectangular ABS "box" upper right, is for JB weld mold step.
The inner rectangular piece is already designed in Thinguiverse. It's easier than having to fill in with the connectors. If you want to adopt it.
Is this the thingiverse part you are referring to? If so, this is for the H480, not the H520 battery plug.
You're right, I've looked into this a long time ago. I use one similar to that but to make the adapter to a normal battery and balance it with the normal JST-XH. It is not valid to make an adapter cable through the balancing pins. The tiredness has given me a bad move :rolleyes:
Sacha
