I remove my quote Thx ... Will try ! Also to be found on wish.comYep it will. The other end is the H520 connector (other picture).
That will give you the total battery voltage not each individual cell.
Well Arruntus, everything went well. They let me out a week before the end of the rehabilitation, that is to say ...
I look assiduously the post on the new firmware 1.5.10, but I'm still waiting before putting it. Anyway, it snows at home and I could not try it immediately.
It remains only to put the trajectories with curve on the H520 and we will have the essential.
Bye.
What's the brand name on that tester and where can you get it?Yes but this one only gives the total voltage and not every cell.
This device gives the voltage of each cell, makes it possible to rebalance the cells between them and also to put the battery in conservation mode while rebalancing the cells.
Thanks!Not exactly the same one, but this one (and clones) are what most folks use:
Tenergy 5-in-1 Intelligent Cell Meter (Capacity Checker, Battery Balancer, Battery Discharger, Internal Resistance Tester, ESC/Servo PPM Tester)
